ocA fault in delta VFD-B series drive
How can resolve problem ocA fault in delta VFD-B series drive ?
Over-current during acceleration
1. Short-circuit at motor output: Check for possible poor insulation at the output lines.
2. Torque boost too high: Decrease the torque compensation setting in Pr.7-02.
3. Acceleration Time too short: Increase the Acceleration Time.
4. AC motor drive output power is too small: Replace the AC motor drive with the next higher power model.
Check wiring.
