Delta VFD-B Series Drive
2
780
May 17, 2022 12:47 pm
How can resolve problem oL fault in delta VFD-B series drive ?
Overload The AC motor drive detects excessive drive output current.
NOTE: The AC motor drive can withstand up to 150% of the rated current for a maximum of 60 seconds.
1. Check whether the motor is overloaded.
2. Reduce torque compensation setting in Pr.7- 02.
3. Use the next higher power AC motor drive model.
Check wiring.
