oL1 fault in delta VFD-B series drive
How can resolve problem oL1 fault in delta VFD-B series drive ?
Overload 1 Internal electronic overload trip
1. Check for possible motor overload.
2. Check electronic thermal overload setting.
3. Use a higher power motor.
4. Reduce the current level so that the drive
output current does not exceed the value set
by the Motor Rated Current Pr.7-00.
Check wiring.
