Delta VFD-B Series Drive
2
878
May 17, 2022 12:44 pm
How can resolve problem ov fault in delta VFD-B series drive ?
Over voltage The DC bus voltage has exceeded its maximum allowable value.
1. Check if the input voltage falls within the
rated AC motor drive input voltage range.
2. Check for possible voltage transients.
3. DC-bus over-voltage may also be caused by
motor regeneration. Either increase the
Decel. Time or add an optional brake resistor
(and brake unit).
4. Check whether the required brake power is
within the specified limits.
