Lv fault in delta VFD-L series drive
How can resolve problem Lv fault in delta VFD-L series drive ?
The AC drive detects that the DC bus voltage has fallen below its minimum value
Check whether the input voltage falls within the rated AC drive’s input voltage.
Check wiring.
