Learn how to perform a factory reset on the Delta M series drive. Discover the specific parameter to restore default settings, ensuring optimal performance and resolving configuration issues.
If you want to factory reset Delta M series drive parameter then use the following step :
2. Then press enter button then display show 00.
3. Then press up button and goto the parameter 76.
4. When display show 76 then press enter button and select 10 then press enter button.
