GFF Ground fault in delta VFD-M series drive
How can resolve problem GFF Ground fault in delta VFD-M series drive ?
Ground fault :
The AC drive output is abnormal.
When the output terminal is grounded (short circuit current is 50% more than the AC drive rated current), the AC drive power module may be damaged.
The short circuit protection is provided for AC drive protection, not user protection.
Ground fault :
1. Check whether the IGBT power module is damaged.
2. Check for possible poor insulation at the output line.
