cE-- fault in delta VFD-S series drive
How can resolve problem cE-- fault in delta VFD-S series drive ?
Communication Error
1. Check the RS485 connection between the AC
motor drive and RS485 master for loose wires
and wiring to correct pins.
2. Check if the communication protocol, address,
transmission speed, etc. are properly set.
3. Use the correct checksum calculation.
