Delta VFD-VE Series Drive
2
739
May 16, 2022 5:16 am
How can resolve problem ocA fault in delta VFD-VE series drive ?
DC BUS over-voltage during acceleration
1. Check if the input voltage falls within the rated AC motor drive input voltage range.
2. Check for possible voltage transients.
3. If DC BUS over-voltage due to regenerative voltage, please increase the Deceleration Time or add an optional brake resistor.
Check wiring.
