ocd fault in delta VFD-VE series drive
How can resolve problem ocd fault in delta VFD-VE series drive ?
DC BUS over-voltage during deceleration
1. Check if the input voltage falls within the rated AC motor drive input voltage range.
2. Check for possible voltage transients.
3. If DC BUS over-voltage due to regenerative voltage, please increase the Deceleration Time or add an optional brake resistor.
Check wiring.
Click2Electro
Get free chat support...
🟢 Online
