EoL1 Servo motor overload fault in delta VJ series Drive
How can resolve problem EoL1 Servo motor overload fault in delta VJ series Drive ?
Topic Tags
Cause : Servo motor overload.
1. Set Pr00-04=30 (v2.06 and above),
observe if the value returns to zero
after every molding cycle. If the
number accumulates to 100, EoL
occurs. Change the molding
conditions.
2. Replace with the hybrid servo drive
with a larger output capacity model.
3. If the pressure –flow is too high
during the blending, such error
occurs easily. To clear this error,
decrease the pressure command and
the flow command.
