GFF Ground fault fault in delta VJ series Drive
How can resolve problem GFF Ground fault fault in delta VJ series Drive ?
Topic Tags
1. Check the wire of hybrid servo motor is shorted or grounded.
2. Check if IGBT power module is damaged
3. Check if the output side wire has bad insulation.
