Delta VFD-VJ Series Drive
2
1,323
Apr 21, 2022 6:27 am
How can resolve problem PGF4 fault in delta VJ series Drive ?
Apr 21, 2022 6:28 am
Cause : PG slip error.
1.Check the PG feedback wiring.
2.Check if PI gain and the settings for
acceleration/ deceleration are suitable.
3.Check if there’s an output phase loss.
4.The causes of these errors could be
loose contact/ disconnection between
encoder, hybrid servo motor drive and
motor. (OC might also occur in different
conditions.).
5.Check if the connection between oil
pump and motor is stuck.
