Fuji FRENIC-MEGA (G2), Eco, Lift & FVR-Micro Drive
138
May 29, 2025 1:08 pm
Cause: Tuning error comes when auto-tuning failed. This fault specifically occurs when the drive's motor autotuning (also known as auto-tuning or auto-setting) process fails or encounters an issue.Â
er7 fault in fuji FRENIC MEGA drive indicates Tuning error. This means the drive failed during auto-tuning of the motor, typically when attempting to identify motor parameters or perform vector control tuning.
- Verify Motor Nameplate Data in Drive Parameters.
- Check Motor Wiring.
- Ensure Motor is Uncoupled/Freely Rotating (if required).
- Select the Correct Autotuning Mode.
- Re-attempt Autotuning.
