er9 Speed mismatch fault in Fuji FRENIC-VG drive
Cause : Speed mismatch comes when an excessive deviation has occurred between the speed command and the detected speed. An ER9 speed mismatch indicates a significant deviation between the commanded speed and the actual speed of the motor controlled by the Fuji FRENIC-VG drive.
"er9" fault in Fuji FRENIC-VG drive indicate " Speed mismatch error". This means a discrepancy between the expected and actual speeds. This fault typically occurs when the drive detects a difference between the commanded speed and the feedback speed from the motor or encoder, or when the drive’s internal speed calculations do not match the expected values.
  1. Check Encoder and Feedback Signals:
    • Inspect the encoder and its wiring for any signs of damage or loose connections.
    • Verify that the encoder is functioning correctly and providing accurate speed feedback.
  2. Verify Speed Settings:
    • Review the drive’s speed settings and parameters to ensure they are correctly configured for the application.
    • Check the commanded speed values and compare them to the actual speed readings from the encoder.
  3. Inspect Mechanical Components:
    • Check the motor and load for any mechanical issues, such as excessive friction, binding, or misalignment, that could affect the speed.
    • Ensure that the motor is properly mounted and that the load is correctly connected.
  4. Check Wiring and Connections:
    • Ensure that all wiring connections between the drive, encoder, and motor are secure and free from damage.
    • Verify that the wiring is correctly connected according to the drive’s wiring diagram.
  5. Review Drive Configuration:
    • Verify that the drive’s configuration settings related to speed control and feedback are correctly set up.
    • Ensure that any calibration or scaling settings for speed feedback are accurate.
