Oh3 Inverter internal overheat fault in Fuji FRENIC-VG drive
Cause : Inverter internal overheat comes when temperature inside the inverter has exceeded the allowable limit. The internal components of the inverter section are overheating.
"Oh3" fault in Fuji FRENIC-VG drive indicate "Inverter internal overheat" condition. This means the internal temperature of the inverter section has exceeded safe operating limits. This fault is a protective measure designed to prevent damage to the drive's components due to excessive heat.
  1. Check Cooling System:
    • Inspect the drive’s cooling fans to ensure they are functioning correctly. Replace any faulty fans.
    • Check that air filters and ventilation paths are clean and free from obstructions. Clean or replace filters as needed.
    • Ensure that the drive is installed with adequate clearance around it for proper ventilation.
  2. Verify Ambient Temperature:
    • Measure the ambient temperature around the drive and ensure it is within the manufacturer’s specified operating range.
    • If the temperature is too high, consider improving the ventilation, adding air conditioning, or relocating the drive to a cooler environment.
  3. Inspect for Overloading:
    • Review the drive’s operating conditions and ensure it is not being overloaded. Reduce the load if necessary.
    • Consider whether the drive is appropriately sized for the application. If not, a larger drive may be required.
  4. Clean the Heat Sink:
    • Power down the drive and carefully access the heat sink. Clean it thoroughly to remove any dust, dirt, or debris that may be affecting heat dissipation.
  5. Check Temperature Sensor:
    • If the heat sink and cooling system are in good condition, the issue may be related to a faulty temperature sensor. Test or replace the sensor if necessary.
    • Verify that the sensor is properly connected and calibrated according to the drive’s specifications.
  6. Inspect Internal Components:
    • If the fault persists, the problem may be with internal components such as IGBTs or capacitors. This may require more in-depth diagnostics or the assistance of a qualified technician.
    • Look for any signs of overheating or damage inside the drive, such as burnt components or discolored circuit boards.
