Difference between Dry Contact and Wet Contact?
Dry contact and wet contact refer to different types of electrical contacts used in various applications. The main difference between them lies in their exposure to environmental conditions and the presence of conductive substances.
  1. Dry Contact:
    • A dry contact refers to a contact that is not exposed to any conductive substances such as water or other liquids.
    • Dry contacts are typically used in electrical circuits where no external substance is present to cause electrical conduction between the contacts.
    • Examples of dry contacts include mechanical switches, relays, and contactors used in dry environments such as control rooms or indoor electrical panels.
    • Dry contacts do not have any conductive material bridging the contacts when they are in their normal state. They rely on external factors (e.g., pressing a button or activating a switch) to bring the contacts together and complete the circuit.
  2. Wet Contact:
    • A wet contact refers to a contact that is exposed to a conductive substance, such as water or other liquids.
    • Wet contacts are typically used in environments where moisture or liquids are present, and electrical conductivity between the contacts is possible.
    • Examples of wet contacts include certain types of sensors, switches, or electrical connectors used in outdoor or industrial environments where exposure to moisture, water, or chemicals is common.
    • Wet contacts may have conductive material bridging the contacts even in their normal state, allowing for electrical conduction to occur when exposed to the conductive substance.
In summary, the main difference between dry contacts and wet contacts is their exposure to conductive substances. Dry contacts are used in environments where no external substances are present to cause electrical conduction between the contacts, while wet contacts are used in environments where exposure to moisture, water, or other conductive substances is possible.
  1. Dry Contact:
  2. Wet Contact:
