Electromagnetic induction type relay
Electromagnetic induction relays, also known as magnitude relays, are a type of relay that utilizes the principles of electromagnetism and induction motors to operate. Unlike traditional electromagnetic relays that rely on attracting an armature with a magnetic coil, induction relays use a rotating disc and the interaction of magnetic fields to achieve switching.
Here's a breakdown of how electromagnetic induction relays work:
Components:
  • Electromagnets: The relay consists of two electromagnets positioned on either side of a metallic disc.
  • Metallic Disc: A thin, conductive disc made of aluminum or another non-magnetic metal is mounted on a shaft and free to rotate within the space between the electromagnets.
  • Shaft and Bearings: The disc is mounted on a shaft with low-friction bearings to allow smooth rotation.
Operation:
  1. Energized Coils: When current flows through the coils of the electromagnets, they generate magnetic fields.
  2. Eddy Currents: The changing magnetic fields from the energized coils induce eddy currents within the metallic disc according to Faraday's law of electromagnetic induction. These eddy currents also generate their own magnetic field.
  3. Motor-like Force: The interaction between the magnetic field of the electromagnets and the eddy current-induced magnetic field in the disc creates a force that tries to rotate the disc.
  4. Torque and Contact Switching: The magnitude of the torque acting on the disc depends on the strength of the magnetic fields, which is proportional to the current flowing through the electromagnet coils. As the current increases, the torque increases, causing the disc to rotate with greater force. Depending on the design, the rotation of the disc actuates a mechanism that switches contacts, similar to how some limit switches work.
Applications:
Electromagnetic induction relays are used in various applications where precise control based on the magnitude of an AC current is required. Here are some examples:
  • Overcurrent Protection: These relays can be used in conjunction with current transformers to provide overcurrent protection for motors and other equipment. The relay setting can be adjusted based on the desired current threshold for tripping.
  • Phase Protection: By monitoring the current in each phase of a three-phase system, induction relays can detect phase imbalances that could damage motors or other equipment.
  • Power Factor Correction: These relays can be used in power factor correction systems to monitor and adjust capacitor banks based on the measured current and improve the overall power factor.
Advantages:
  • High Sensitivity: Induction relays offer high sensitivity to changes in current magnitude, making them suitable for precise control applications.
  • Fast Response: Due to the rotating disc mechanism, these relays can have fast response times compared to some traditional relays.
  • No Contact Wear: Since the switching mechanism doesn't rely on physically making and breaking contacts, induction relays experience less wear and tear, leading to longer lifespans.
Disadvantages:
  • Complexity: The design of induction relays is more complex compared to simpler electromagnetic relays.
  • Cost: Due to their design and functionality, induction relays are generally more expensive than basic electromagnetic relays.
  • AC Only: These relays typically function with AC currents and might not be suitable for direct current (DC) applications.
In conclusion, electromagnetic induction relays offer a unique approach to current sensing and control using the principles of electromagnetism and induction. While they might be more complex and expensive than traditional relays, their high sensitivity, fast response, and reduced contact wear make them valuable assets for specific applications requiring precise control based on AC current magnitude.
