Free wheeling diode
A freewheeling diode, also known as a flyback diode, freewheeling rectifier, or snubber diode, is a diode connected across an inductive load in a circuit. It is used to provide a path for the current to flow when the inductive load is switched off, preventing voltage spikes and protecting other components in the circuit.
Here's how a freewheeling diode works and why it's used:
  1. Operation:
    • When an inductive load, such as a relay coil or a motor, is switched off, the magnetic field collapses, inducing a reverse voltage across the load. This reverse voltage can cause voltage spikes that may damage other components in the circuit, such as transistors or switches.
    • The freewheeling diode is connected across the inductive load in reverse bias configuration. When the load is switched off, the freewheeling diode conducts, providing a path for the current to continue flowing through the inductive load. This allows the energy stored in the inductive load to dissipate gradually without causing voltage spikes.
  2. Purpose:
    • The primary purpose of a freewheeling diode is to protect other components in the circuit from voltage spikes generated by inductive loads. By providing a low-resistance path for the current to circulate, the freewheeling diode clamps the voltage across the load to a safe level, preventing damage to sensitive components.
    • Additionally, freewheeling diodes help improve the efficiency and reliability of the circuit by reducing electromagnetic interference (EMI) and minimizing the risk of component failure due to voltage transients.
  3. Applications:
    • Freewheeling diodes are commonly used in various electronic circuits involving inductive loads, including:
      • Relay circuits: to protect the switching transistor or relay driver from voltage spikes generated by the relay coil.
      • Motor control circuits: to protect the motor driver or power transistors from voltage spikes generated by the motor windings.
      • Solenoid valve circuits: to protect the solenoid driver from voltage spikes generated by the solenoid coil.
      • Transformer-based power supplies: to protect the rectifier diodes from voltage spikes generated by the transformer's primary winding.
  4. Selection:
    • When selecting a freewheeling diode, it's essential to choose a diode with suitable voltage and current ratings to handle the maximum reverse voltage and current generated by the inductive load.
    • Fast-recovery diodes are often preferred for high-frequency applications to minimize switching losses and improve efficiency.
In summary, a freewheeling diode is a crucial component in circuits with inductive loads, providing protection against voltage spikes and ensuring the safe and reliable operation of the circuit. Its role is to dissipate the energy stored in the inductive load when it is switched off, preventing damage to other components and improving the overall performance of the circuit.
