Manometer: Definition, Diagram, Working & Types
A manometer is a device used for measuring pressure, typically in a fluid such as liquid or gas. It works on the principle that the pressure exerted by a fluid at any given point is transmitted undiminished in all directions. Manometers are commonly used in various industries, laboratories, and engineering applications for pressure measurement.
Diagram: A typical manometer consists of a U-shaped tube partially filled with a liquid (usually mercury, water, or oil), with one end connected to the pressure source and the other open to the atmosphere or connected to a reference pressure. Here's a simplified diagram:
               |        Fluid        |
Working: The working principle of a manometer relies on the balance of pressure exerted by the fluid being measured and the reference pressure. When the pressure on one side of the U-tube differs from the pressure on the other side, the fluid level in the tube changes. This change in fluid level is directly proportional to the pressure difference between the two points.
Types:
  1. Simple Manometer: Consists of a single U-shaped tube partially filled with a liquid.
  2. Differential Manometer: Used to measure the pressure difference between two points in a system.
  3. Inclined Manometer: The U-tube is tilted at an angle, allowing measurement of small pressure differences more accurately.
  4. U-Tube Manometer: The most common type, where the U-shaped tube is straight and has a single column of liquid.
  5. Well-Type Manometer: Similar to a U-tube manometer but has a reservoir (well) at the bottom to prevent excessive movement of the fluid.
  6. Micro-Manometer: Designed for measuring very low pressures with high precision.
  7. Digital Manometer: Utilizes digital technology for pressure measurement and display, offering ease of use and accuracy.
Manometers are used in various applications, including HVAC systems, fluid mechanics experiments, industrial process control, and medical equipment calibration. They provide accurate and reliable pressure measurements essential for ensuring the proper functioning and safety of many systems.
