Megger tester
A "Megger tester" is a instrument which measure the insulation resistance of electrical systems, cables, wires, and equipment.
A "Megger tester" also known as a megohmmeter or insulation resistance tester, is a specialized instrument used in electrical maintenance and testing. Its primary function is to measure the insulation resistance of electrical systems, cables, wires, and equipment.
Here are some key features and functions of a Megger tester:
  1. Insulation Resistance Measurement: A Megger tester applies a high voltage, typically ranging from 250 volts to several kilovolts, to the insulation of the component under test. It then measures the resulting current flow and calculates the insulation resistance using Ohm's law.
  2. Resistance Measurement Range: Megger testers are capable of measuring a wide range of insulation resistances, from very low values to several gigaohms, depending on the model and application requirements.
  3. Voltage Range: These testers can apply different test voltages depending on the insulation system being tested. Common test voltages include 250V, 500V, 1000V, 2500V, and 5000V, among others.
  4. Resistance Display: Megger testers typically have a digital or analog display to show the measured insulation resistance directly in ohms.
  5. Continuity Testing: Some Megger testers include a continuity test function, allowing users to check the continuity of conductors and connections.
  6. Safety Features: Megger testers are designed with safety features to protect the user and the equipment under test from electrical hazards. These may include overvoltage protection, automatic discharge of capacitive loads, and insulation resistance alarms.
Megger testers are essential tools for preventive maintenance, troubleshooting, and commissioning of electrical systems in various industries, including power generation, distribution, manufacturing, and telecommunications. Regular insulation resistance testing helps identify potential insulation defects, moisture ingress, and deterioration, thereby preventing electrical failures and ensuring the safety and reliability of electrical installations.
