PURPOSE OF A VOLTAGE FOLLOWER
A voltage follower, also known as a unity-gain amplifier or a buffer amplifier, is an electronic circuit that has a voltage gain of approximately one (unity) and mimics the input voltage at its output. The primary purpose of a voltage follower is to isolate the input signal source from the load and provide impedance matching between the source and the load. Here are some key purposes and applications of voltage followers:
  1. Impedance Matching: Voltage followers are often used to match the output impedance of a signal source to the input impedance of a load device. This helps prevent signal distortion, reflections, and losses that can occur when there is a mismatch between source and load impedances.
  2. Signal Isolation: Voltage followers provide isolation between the input signal source and the load, ensuring that the load does not affect the performance or characteristics of the source. This is particularly useful when driving sensitive or high-impedance loads that could otherwise load down or distort the source signal.
  3. Signal Buffering: Voltage followers act as signal buffers by presenting a high input impedance to the source and a low output impedance to the load. This helps prevent loading effects on the source and ensures that the signal remains unaffected by changes in load conditions.
  4. Signal Conditioning: Voltage followers can be used for signal conditioning purposes, such as impedance transformation, level shifting, and signal amplification. By maintaining a constant voltage gain of one, voltage followers preserve the amplitude and waveform of the input signal while providing the necessary buffering and impedance matching.
  5. Feedback Applications: Voltage followers are commonly used as buffer stages in feedback control systems, instrumentation circuits, and operational amplifier (op-amp) circuits. They help isolate feedback networks from the input and output stages, improving stability, linearity, and frequency response.
  6. Driver Circuits: Voltage followers can serve as driver circuits to provide high-current drive capability for low-impedance loads or to isolate sensitive input stages from the output stage of a system. They help improve the load-driving capability and performance of the overall circuit.
  7. Biasing and Bias Stability: Voltage followers can be used to stabilize biasing circuits and provide a stable reference voltage or bias level for other components in a circuit. They ensure that the biasing conditions remain unaffected by changes in load or environmental conditions.
Overall, voltage followers play a crucial role in electronic circuits by providing impedance matching, signal isolation, buffering, and signal conditioning capabilities. They are widely used in various applications, including audio amplifiers, sensor interfaces, instrumentation circuits, feedback control systems, and communications systems, where preserving signal integrity and ensuring proper interfacing between different circuit stages are essential.
