Stepper motors working types
Stepper motors are widely used in various applications due to their precise control of rotation angle and speed. There are several types of stepper motors based on their construction and operation. Here are the common types:
  1. Permanent Magnet Stepper Motor (PM Stepper Motor): These motors have a permanent magnet rotor and toothed stator poles. The rotor aligns with the magnetic field generated by the stator poles when energized, causing rotation. PM stepper motors have relatively low torque but are cost-effective and widely used in applications such as printers, scanners, and disk drives.
  2. Variable Reluctance Stepper Motor (VR Stepper Motor): VR stepper motors have a toothed rotor and stator with salient poles. The rotor rotates to minimize the reluctance of the magnetic circuit when stator poles are energized sequentially. These motors typically have higher torque than PM motors but may suffer from vibration and noise. They find applications in low-cost motion control systems.
  3. Hybrid Stepper Motor: Hybrid stepper motors combine features of both PM and VR stepper motors. They have a permanent magnet rotor with teeth and a stator with salient poles and windings. Hybrid stepper motors offer higher torque, better precision, and less vibration compared to other types. They are widely used in CNC machines, 3D printers, and robotics.
  4. Single Stack vs. Multi-stack: Stepper motors can be categorized based on the number of rotor and stator stacks they have. Single-stack motors have one rotor and stator stack and are suitable for applications requiring lower torque. Multi-stack motors have multiple rotor and stator stacks, providing higher torque output and better performance in demanding applications.
  5. Bipolar vs. Unipolar: Stepper motors can also be classified based on their winding configuration. Bipolar stepper motors have two coils per phase and require a bipolar drive circuit for operation. Unipolar stepper motors have a center-tapped coil per phase, allowing them to be driven using simpler unipolar drive circuits. Bipolar motors generally offer better performance and torque compared to unipolar motors, but they require more complex drive electronics.
Each type of stepper motor has its advantages and disadvantages, and the choice depends on factors such as torque requirements, precision, cost, and application-specific needs.
