TYPES OF ELECTRIC BRAKING IN DC MOTOR
Electric braking in DC motors refers to the various methods used to bring the motor to a stop or slow down its rotation by applying an electric braking force. Here are some common types of electric braking techniques used in DC motors:
  1. Dynamic Braking:
    • Dynamic braking, also known as regenerative braking, involves short-circuiting the motor terminals or connecting them across a resistor during deceleration. This creates a path for the motor's back EMF (electromotive force) to circulate within the motor windings, generating a braking torque that opposes the motor's rotation. The energy dissipated in the resistor is typically converted into heat. Dynamic braking is effective for quickly stopping or decelerating the motor and is commonly used in applications where rapid stopping is required, such as elevators, cranes, and electric trains.
  2. Plugging Braking:
    • Plugging braking, also known as reverse voltage braking or dynamic plugging, involves reversing the polarity of the motor terminals during deceleration. This causes the motor to generate a reverse torque that opposes its rotation, effectively bringing it to a stop. Plugging braking can be achieved by reversing the direction of current flow in the armature or field windings of the motor. While plugging braking provides quick stopping action, it can cause mechanical stress and wear on the motor and should be used judiciously.
  3. Regenerative Braking:
    • Regenerative braking is a method of braking that recovers energy from the motor during deceleration and feeds it back into the electrical system for reuse. Instead of dissipating the braking energy as heat, regenerative braking converts it into electrical energy, which can be stored in a battery or returned to the power supply. This method is commonly used in electric vehicles, hybrid vehicles, and electric trains to improve energy efficiency and extend battery life.
  4. Counter-Electromotive Force (CEMF) Braking:
    • CEMF braking involves momentarily disconnecting the motor from the power supply and allowing the motor's counter-electromotive force (back EMF) to generate a braking torque. This method relies on the natural deceleration of the motor due to its inertia and the opposing torque generated by the back EMF. CEMF braking is a passive braking method that does not require additional braking components and is often used in simple DC motor control applications.
Each type of electric braking method has its advantages and limitations, and the selection of the appropriate braking technique depends on factors such as the application requirements, motor characteristics, braking torque requirements, and energy efficiency considerations.
