TYPES OF FUSES AND HOW TO SELECT A FUSE?
Fuses are protective devices used in electrical circuits to interrupt the flow of current when it exceeds a safe level, thereby preventing damage to equipment and preventing electrical hazards such as fires and shocks. There are various types of fuses available, each designed for specific applications and operating conditions. Here are some common types of fuses:
  1. Cartridge Fuses:
    • Cartridge fuses consist of a fuse element enclosed in a cylindrical or tubular housing made of glass or ceramic.
    • They are available in different sizes, voltage ratings, and current ratings to suit various applications.
    • Cartridge fuses may be fast-acting or time-delay (slow-blow) fuses, depending on their response time to overcurrent conditions.
  2. Blade Fuses:
    • Blade fuses, also known as automotive fuses, are commonly used in vehicles and automotive electrical systems.
    • They feature a plastic housing with two metal blades that plug into fuse blocks or holders.
    • Blade fuses are available in standard sizes such as mini, standard (ATO), and maxi, each with different current ratings.
  3. Resettable Fuses (PTCs):
    • Resettable fuses, also known as polymeric positive temperature coefficient (PPTC) devices or polymer resettable fuses, are designed to automatically reset after tripping when the fault condition is removed.
    • They operate based on the principle of a positive temperature coefficient (PTC), where the resistance increases when the temperature rises due to overcurrent conditions.
  4. Surface Mount Fuses:
    • Surface mount fuses are compact fuses designed for use on printed circuit boards (PCBs) and surface mount technology (SMT) applications.
    • They are available in various package styles such as chip, rectangular, or cylindrical designs.
    • Surface mount fuses offer high reliability and are commonly used in electronic devices and equipment.
  5. High Voltage Fuses:
    • High voltage fuses are designed to protect high voltage electrical systems and equipment from overcurrent conditions.
    • They are available in various designs such as expulsion, current-limiting, and power fuses, each suitable for specific voltage and current ratings.
  6. Specialty Fuses:
    • Specialty fuses include types such as semiconductor fuses, indicating fuses, and photovoltaic (PV) fuses, designed for specific applications and industries.
    • Semiconductor fuses are used to protect semiconductor devices such as diodes, transistors, and thyristors.
    • Indicating fuses feature a built-in indicator that signals when the fuse has operated.
    • PV fuses are designed for photovoltaic (solar power) systems to protect against overcurrent conditions.
When selecting a fuse for a particular application, several factors should be considered:
  1. Current Rating: The fuse must have a current rating appropriate for the maximum current expected under normal operating conditions.
  2. Voltage Rating: The fuse must have a voltage rating equal to or higher than the voltage of the circuit it is protecting.
  3. Response Time: Depending on the application, the fuse may need to have a fast-acting or time-delay (slow-blow) characteristic to provide adequate protection without unnecessary nuisance tripping.
  4. Environmental Conditions: Consideration should be given to factors such as temperature, humidity, and altitude, which may affect the performance and reliability of the fuse.
  5. Agency Approvals: Ensure that the fuse meets relevant safety standards and agency approvals for the intended application and industry.
By carefully considering these factors and selecting the appropriate type and rating of fuse, you can ensure effective protection of electrical circuits and equipment against overcurrent conditions and ensure safe and reliable operation.
