What is a transmission power line? Why DC is not used for power transmission?
A transmission power line, often simply called a power line or transmission line, is a structure used to transmit electrical power from generating stations (such as power plants) to substations and then to distribution networks that deliver power to homes, businesses, and other consumers. These lines typically consist of conductors made of materials like aluminum or copper, supported by towers or poles, and are insulated to prevent power loss and ensure safety.
The choice of using alternating current (AC) rather than direct current (DC) for power transmission is based on several factors:
  1. Losses in Transmission: With AC transmission, it's possible to step up the voltage using transformers, allowing for long-distance transmission with lower losses due to reduced current flow. In DC transmission, there are higher losses over long distances because voltage cannot be easily stepped up or down without complex converter stations.
  2. Cost of Equipment: AC transmission lines require less expensive equipment for voltage regulation and transformation compared to DC transmission lines.
  3. Frequency of AC: The ability to change voltage levels with transformers in AC systems allows for the use of different frequencies. High voltage AC transmission is commonly used because it can be easily transformed to various voltage levels, whereas DC transmission typically requires more expensive conversion equipment.
  4. Historical Development: AC transmission systems were developed and widely implemented before DC transmission technologies became feasible on a large scale. This historical precedence has led to widespread infrastructure built around AC transmission.
While DC transmission does have some advantages, such as lower losses in certain situations and the ability to control power flow more precisely, these advantages have historically been outweighed by the factors favoring AC transmission. However, advancements in high-voltage direct current (HVDC) technology have led to its increased use in certain applications, particularly for long-distance transmission under specific conditions where its benefits outweigh those of AC transmission.
