What is circuit breaker?
A circuit breaker is an electrical switching device designed to protect electrical circuits from damage caused by overload, short circuit, or other faults. It functions as a safety mechanism by automatically interrupting the flow of current in a circuit when abnormal conditions occur, thereby preventing overheating, fires, and damage to electrical equipment.
Here's how a circuit breaker typically works:
  1. Switching Mechanism: A circuit breaker consists of a switching mechanism that opens and closes electrical contacts to control the flow of current in a circuit. When the circuit breaker is in the closed position, current flows through it as normal. When a fault occurs, the circuit breaker automatically opens to interrupt the current flow.
  2. Tripping Mechanism: Circuit breakers are equipped with a tripping mechanism that detects abnormal conditions such as overload, short circuit, or ground fault. This mechanism may include sensors, electromechanical devices, or electronic components that monitor the current flowing through the circuit.
  3. Trip Response: When the tripping mechanism detects an abnormal condition, it triggers the circuit breaker to open the contacts rapidly. This action interrupts the flow of current in the circuit, effectively isolating the faulty section of the circuit from the rest of the electrical system.
  4. Arc Extinction: During the opening of the contacts, an arc may form between them due to the interruption of the current flow. Circuit breakers are designed to extinguish this arc quickly and safely to prevent damage to the contacts and surrounding equipment. This is achieved through various techniques such as arc chutes, magnetic blowout coils, or arc quenching media.
  5. Reset Mechanism: After the fault has been cleared and the abnormal condition has been resolved, the circuit breaker can be manually or automatically reset to close the contacts and restore power to the circuit. Some circuit breakers feature automatic reset functions, while others require manual intervention to reset.
Circuit breakers are essential components of electrical distribution systems, providing protection for residential, commercial, and industrial applications. They come in various types and ratings to suit different voltage levels, current capacities, and applications. Common types of circuit breakers include miniature circuit breakers (MCBs), molded case circuit breakers (MCCBs), residual current circuit breakers (RCCBs), and air circuit breakers (ACBs). Circuit breakers play a crucial role in ensuring the safety and reliability of electrical systems by preventing hazards associated with electrical faults.
