What is Electromagnetic Relay? Definition & Types
An electromagnetic relay is an electrically operated switch that uses an electromagnetic mechanism to control a circuit. It essentially acts as a remote-controlled switch, allowing a low-power control signal to operate a high-power circuit.
How Does it Work?
  1. Coil: When an electric current is passed through a coil within the relay, it generates a magnetic field.
  2. Armature: This magnetic field attracts a movable iron component called an armature.
  3. Contacts: The movement of the armature causes a set of contacts to open or close, thereby controlling the flow of current in the main circuit.
Types of Electromagnetic Relays
There are several types of electromagnetic relays, each with its own specific characteristics and applications:
  • General-Purpose Relays: These are the most common type, used for a wide range of applications. They have a simple construction and are relatively inexpensive.
  • Contactor Relays: Designed for heavy-duty applications, contactor relays can handle large currents and voltages. They are often used in industrial control systems.
  • Time-Delay Relays: These relays incorporate a delay mechanism that prevents the contacts from closing or opening immediately after the coil is energized. They are used in applications where a specific delay is required.
  • Polarized Relays: These relays are sensitive to the polarity of the applied voltage. They are often used in AC circuits to detect phase reversal or other specific conditions.
  • Reed Relays: Reed relays use a sealed glass capsule containing two thin metal reeds. When a magnetic field is applied, the reeds come into contact, closing the circuit. Reed relays are known for their fast switching speed and long life.
Common Applications of Electromagnetic Relays
  • Industrial control systems: Controlling motors, heaters, and other equipment.
  • Automotive systems: Controlling lights, wipers, and other components.
  • Home appliances: Controlling various functions, such as heating, cooling, and security.
  • Telecommunications: Switching circuits in telephone systems.
