What is Hysteresis loss?
Hysteresis loss, also known as hysteresis energy loss, is a phenomenon that occurs in ferromagnetic materials when they are subjected to alternating magnetic fields. This loss results from the repeated magnetization and demagnetization cycles experienced by the material as the magnetic field alternates direction.
Here's a breakdown of the key points about hysteresis loss:
  1. Cause: When a ferromagnetic material, such as iron or steel, is exposed to an alternating magnetic field, the magnetic domains within the material align with the field. However, due to the inherent resistance of the material to changes in magnetization, there is a delay or lag in the alignment of the domains with the changing field. This lag creates a loop in the magnetization curve known as the hysteresis loop.
  2. Energy Loss: The area enclosed by the hysteresis loop represents the energy loss per unit volume of the material per cycle. This energy loss occurs because energy is required to overcome the resistance to magnetization during each cycle, and some of this energy is dissipated as heat within the material.
  3. Effect on Efficiency: Hysteresis loss results in energy dissipation and heating within magnetic components such as transformers, inductors, and magnetic cores of electric motors. This energy loss reduces the efficiency of these devices and contributes to heating, which may necessitate additional cooling measures.
  4. Minimization: Engineers aim to minimize hysteresis loss by selecting materials with low hysteresis characteristics, such as materials with narrow hysteresis loops. Additionally, the design of magnetic components can be optimized to minimize the effect of hysteresis loss on overall system efficiency.
  5. Frequency Dependence: Hysteresis loss tends to increase with increasing frequency of the alternating magnetic field. This frequency dependence is due to the limited time available for the magnetic domains to realign with the changing field direction at higher frequencies, leading to increased energy loss.
In summary, hysteresis loss is a phenomenon associated with ferromagnetic materials exposed to alternating magnetic fields, resulting in energy dissipation and heat generation. It is an important consideration in the design and operation of magnetic components in electrical and electronic systems.
