What is IP rating ? Why to use IP rating?
IP rating, or Ingress Protection rating, is a standardized classification system used to define the degree of protection provided by enclosures or housings against the intrusion of solid objects (such as dust and dirt) and liquids (such as water) into electrical or mechanical components.
The IP rating system consists of two digits:
  1. The first digit indicates the level of protection against solid objects.
  2. The second digit indicates the level of protection against liquids.
Each digit ranges from 0 to 6, with higher numbers indicating higher levels of protection. Some additional levels may be denoted by the digit 'X', meaning that the enclosure has not been rated for that particular type of protection.
Here's a breakdown of the IP rating system:
  • First Digit (Protection against Solid Objects):
    • 0: No protection.
    • 1: Protection against solid objects larger than 50mm in diameter.
    • 2: Protection against solid objects larger than 12.5mm in diameter.
    • 3: Protection against solid objects larger than 2.5mm in diameter.
    • 4: Protection against solid objects larger than 1mm in diameter.
    • 5: Limited protection against dust ingress (dust-protected).
    • 6: Complete protection against dust ingress (dust-tight).
  • Second Digit (Protection against Liquids):
    • 0: No protection.
    • 1: Protection against vertically falling water droplets.
    • 2: Protection against water droplets at an angle of up to 15° from vertical.
    • 3: Protection against spraying water at an angle of up to 60° from vertical.
    • 4: Protection against splashing water from any direction.
    • 5: Protection against water jets from any direction.
    • 6: Protection against powerful water jets and waves.
    • 7: Protection against temporary immersion in water (up to 1 meter for 30 minutes).
    • 8: Protection against continuous immersion in water under specified conditions (depth and duration specified by the manufacturer).
The primary reasons for using IP ratings are as follows:
  1. Protection of Equipment: IP ratings help ensure that electrical and electronic equipment is adequately protected from ingress of solid objects and liquids. This protection is crucial to prevent damage to sensitive components and ensure the proper functioning of equipment in various environments.
  2. Safety: IP-rated enclosures provide a level of safety for users by reducing the risk of electric shock, fire, or equipment failure due to exposure to dust, dirt, water, or other environmental hazards.
  3. Compliance with Standards: Many industries and regulatory bodies require equipment to meet specific IP rating standards to ensure safety, reliability, and compliance with regulations and standards.
  4. Selection of Suitable Equipment: IP ratings help users select the most appropriate equipment for specific applications and environments based on the level of protection required against solid objects and liquids.
  5. Reliability and Longevity: Equipment with higher IP ratings generally exhibits greater reliability and longevity, as it is better protected against environmental factors that can cause degradation or failure over time.
In summary, IP ratings provide a standardized method for specifying the degree of protection provided by enclosures against ingress of solid objects and liquids. By using IP ratings, manufacturers, engineers, and users can ensure that electrical and electronic equipment is adequately protected and suitable for use in various applications and environments.
