What is pressure sensor?
A pressure sensor is a device that measures pressure and converts it into an electrical signal. These sensors are used to monitor and control pressure levels in various systems and processes across different industries.
Here's how a pressure sensor typically works:
  1. Pressure Sensing Element: The heart of a pressure sensor is its sensing element, which is designed to deform in response to changes in pressure. The sensing element may take various forms depending on the type of pressure being measured and the operating conditions. Common types of sensing elements include:
    • Strain Gauge: A flexible material (e.g., metal foil or semiconductor) bonded to a diaphragm or membrane that deforms under pressure, causing changes in electrical resistance.
    • Piezoelectric Crystal: A crystal that generates an electrical charge when subjected to mechanical stress, such as pressure, resulting in a voltage output proportional to the applied pressure.
    • Capacitive: Two parallel plates separated by a dielectric material, with changes in pressure causing variations in capacitance, which are then converted into an electrical signal.
  2. Signal Conditioning: The electrical signal generated by the pressure sensing element is typically weak and may require amplification, filtering, and linearization to improve accuracy and reliability. Signal conditioning circuits are used to process the raw sensor output and convert it into a standardized electrical signal, such as voltage, current, or digital data.
  3. Output: The processed electrical signal is the output of the pressure sensor, which can be used for display, recording, control, or communication purposes. The output signal is often proportional to the applied pressure and may be linear or nonlinear depending on the sensor's design and calibration.
  4. Types of Pressure Sensors:
    • Absolute Pressure Sensor: Measures pressure relative to a perfect vacuum (absolute zero pressure).
    • Gauge Pressure Sensor: Measures pressure relative to atmospheric pressure.
    • Differential Pressure Sensor: Measures the difference in pressure between two points.
    • Sealed Pressure Sensor: Measures pressure relative to a sealed reference chamber, suitable for measuring high pressures or pressures in corrosive environments.
    • Vacuum Pressure Sensor: Measures pressures below atmospheric pressure (negative pressure or vacuum).
Pressure sensors are widely used in various industries and applications, including automotive, aerospace, medical devices, industrial automation, HVAC systems, process control, and consumer electronics. They play a critical role in monitoring and controlling pressure levels to ensure safe and efficient operation of systems and processes.
