What is the limit- switch?
A limit switch is a type of sensor or control device that is used to detect the presence or absence of an object, usually in industrial automation applications. It consists of an actuator (a mechanical lever or button) and a set of electrical contacts. When the actuator is triggered by the movement of an object, it causes the contacts to open or close, thereby signaling the presence or absence of the object or reaching a specific position.
Limit switches are commonly used to control machinery and equipment by detecting the position of moving parts, such as the end of travel of a conveyor belt, the opening or closing of a valve, or the position of a robotic arm. They can also be used for safety purposes, such as detecting when a door is open or closed, or when a machine has reached a dangerous condition.
Limit switches can be configured in various ways depending on the application requirements. They may be normally open (NO), normally closed (NC), or have both NO and NC contacts. Additionally, they can be designed for different environmental conditions, such as high temperatures, corrosive environments, or areas with high vibration.
Overall, limit switches provide a reliable and cost-effective means of sensing the position or status of objects in industrial automation and control systems.
