What is tidal energy and how does it work?
Tidal energy is a form of renewable energy that harnesses the kinetic energy of tidal currents and the potential energy of tidal fluctuations to generate electricity. It relies on the gravitational forces between the Earth, Moon, and Sun, which cause the periodic rise and fall of ocean tides.
Here's how tidal energy works:
  1. Tidal Range Technology:
    • Tidal range technology harnesses the potential energy stored in the difference in height (or tidal range) between high and low tides.
    • Tidal barrages or tidal fences are constructed across estuaries or bays where tidal range is significant. These structures feature sluice gates or turbines that capture water during high tide and release it during low tide, driving turbines to generate electricity.
    • As the tide rises, water is allowed to flow into the basin behind the barrage, filling it with potential energy. When the tide falls, the sluice gates or turbines are opened, and the stored water flows out, driving turbines to generate electricity.
  2. Tidal Stream Technology:
    • Tidal stream technology captures the kinetic energy of tidal currents by deploying underwater turbines or similar devices in areas with strong tidal currents, such as channels between islands or along coastlines.
    • Tidal turbines are anchored to the seabed or installed on floating platforms. As tidal currents flow past the turbines, they spin the rotor blades, which drive generators to produce electricity.
    • Tidal stream technology operates similarly to wind turbines but in an underwater environment. The density of water compared to air means tidal turbines can generate power with relatively slow-moving currents.
  3. Dynamic Tidal Power (DTP):
    • Dynamic tidal power is a theoretical concept that involves constructing a series of long dams or barrages perpendicular to the coastline in shallow seas or straits.
    • As tidal currents flow around these structures, they create a height difference between the upstream and downstream sides of the dam. This height difference drives turbines to generate electricity.
    • Dynamic tidal power aims to harness the energy of ocean currents without the need for a significant tidal range, making it potentially applicable in a wider range of locations.
Tidal energy offers several advantages as a renewable energy source, including predictability (due to the regularity of tidal cycles), high energy density, and minimal visual and environmental impact compared to other forms of renewable energy. However, it also faces challenges such as high upfront costs, limited availability of suitable sites, and potential impacts on marine ecosystems. Ongoing research and development efforts are focused on overcoming these challenges and unlocking the full potential of tidal energy as a clean and sustainable energy source.
