E17.00 fault in inovance IS580 drive
Cause : Pre-charge relay fault comes when hardware issue in drive power card. This means that drive board and power supply are abnormal and the lightning protection board is abnormal.
E17.00 fault in inovance IS580 drive indicates Pre-charge relay fault. This means the drive’s power-up sequence when it tries to safely charge the DC bus capacitors through a pre-charge resistor. This fault indicates that the DC bus voltage did not rise correctly, or the pre-charge relay failed to close or switch properly.
  1. Replace drive board or power supply board.
  2. Replace the lightning protection board.
