Inovance CP700 – Air compressor & IS580 – Injunction Molding Drive
18
May 29, 2025 6:42 am
Cause : Auto tuning speed feedback fault comes when only during rotating auto-tuning and means the drive couldn't verify motor speed during the test run.
E20.00 fault in the Inovance IS580 drive means “Auto-tuning Speed Feedback Fault”. This means the drive tried to perform rotating auto-tuning, but it didn’t receive valid speed feedback from the encoder or internal estimation.
- Encoder is not matched.
- Set the type of encoder correctly.
- Encoder wiring is incorrect.
- Check the PG card power supply and phase sequence.
- Encoder is damaged.
- Replace encoder
- PG card is abnormal.
- Replace PG card.
