Inovance CP700 – Air compressor & IS580 – Injunction Molding Drive
14
May 29, 2025 6:47 am
Cause : Motor ground fault comes when one or more of the motor phases (U/V/W) are shorted to earth/ground.
E23.00 fault in inovance IS580 drive indicates a Motor Ground Fault. This means the drive has detected that current is leaking from the motor or motor cables to ground, which is a serious safety issue and can damage the drive.
- Wiring of inverter and motor get phase-to-phase short circuit.
- Damage of the inverting module IGBT.
- Check whether the electric motor coil is short circuit.
- A failed gate drive board or power board.
- The drive inverter section (IGBT) is shorted.
