E23.09 fault in inovance IS580 drive
Cause: Motor ground fault comes when motor suddenly starts running at high speed upon power-up, and the drive detects a ground fault.
E23.09 fault on an Inovance IS580 drive is a Motor Ground Fault, just like E23.00, but it is a special condition fault triggered during power-on or auto-start scenarios — specifically when the motor suddenly starts running at high speed upon power-up, and the drive detects a ground fault.
  • Check motor insulation resistance (most important).
  • Disconnect motor and power up drive.
  • Inspect motor wiring and terminal box.
  • Inspect drive output terminals: Look at U/V/W terminals for arcing or contamination.
