E44.02 fault in inovance IS580 drive
E44.02 fault in inovance IS580 drive indicates Speed sensor fault. This means the drive is not receiving valid or reliable feedback from the connected speed sensor — such as an incremental encoder or resolver — while operating in closed-loop control mode.
  • Check all connections for tightness and continuity.
  • Inspect for bent pins, damaged cables, or EMI noise.
  • If possible, swap the encoder with a known-good one to verify the issue.
