Inovance CP700 – Air compressor & IS580 – Injunction Molding Drive
67
May 29, 2025 7:52 am
E45.00 fault in inovance IS580 drive indicates Motor PTC overheat. This means the resistance of the PTC exceeds a set threshold.
- Power off and allow the motor to cool for 15–30 minutes.
- Make sure PTC wires are connected to the correct terminals on the drive (typically a dedicated analog/PTC input).
- Ensure fans are running and air passages are clear.
- Check ambient temperature is within rated range.
