E45.01 fault in inovance IS580 drive
E45.01 fault in inovance IS580 drive indicates "Temperature sensor disconnected". This means the drive is configured to monitor a motor temperature sensor (typically a PTC, NTC, or RTD like PT100), but it detects no valid signal.
  • Inspect the motor temperature sensor cable from motor to drive.
  • Confirm correct terminal connections.
  • Check for loose terminals, broken wires, or bent pins.
