E45.03 fault in inovance IS580 drive
E45.03 fault in inovance IS580 drive indicates Motor KTY overheat. This means the drive has detected that the KTY sensor resistance indicates the motor is overheating.
  • The drive monitors the resistance of the KTY sensor to detect if the motor temperature is too high.
  • Power off the drive and wait for the motor to cool.
  • If the fault clears after cooling, the overheat was real.
  • Inspect wiring harness and connectors between the motor and drive.
  • Confirm there are no loose connections or broken wires.
