Inovance CP700 – Air compressor & IS580 – Injunction Molding Drive
148
May 29, 2025 8:29 am
E46.00 fault in inovance IS580 drive indicates "Pressure sensor is faulty". This means the drive has detected a problem with the pressure sensor input signal.
- Check cables, connectors, and terminals for damage or looseness.
- Ensure shielded cables are grounded properly to avoid noise.
- Confirm that the pressure sensor receives the correct supply voltage (often 24V or specific analog voltage).
- Measure the sensor output signal (usually analog voltage or current).
