Inovance CP700 – Air compressor & IS580 – Injunction Molding Drive
12
May 29, 2025 8:37 am
E46.02 fault in inovance IS580 drive indicates pressure sensor calibration fault. This means the drive has detected a problem during the pressure sensor calibration process, indicating the sensor readings don’t match expected values or calibration parameters.
- Check if pressure feedback is around zero.
- Check if pressure sensor is well connected.
- Check if F4-28 to 31 are set properly.
