Inovance CP700 – Air compressor & IS580 – Injunction Molding Drive
131
May 29, 2025 8:39 am
E46.03 fault in inovance IS580 drive indicates that the "pressure sensor output is beyond setting range". This means the analog signal from the connected pressure sensor is outside the acceptable range defined in the drive's settings.
- Pressure sensor output is beyond setting range [A3- 55, A3-56], please check the sensor.
