Inovance CP700 – Air compressor & IS580 – Injunction Molding Drive
129
May 29, 2025 9:16 am
E49.02 fault in inovance IS580 drive indicates Speed sensor interfered. This means the drive is detecting abnormal or unstable signals from the speed sensor — likely due to electrical interference, signal noise, or inconsistent pulse feedback. It means the sensor is connected, but the feedback is noisy, distorted, or unreliable.
- Check for loose connectors, broken wires, or damaged cables.
- Make sure the encoder/resolver cable is shielded.
- The shield should be grounded at one point only (preferably at the drive side).
