Inovance CP700 – Air compressor & IS580 – Injunction Molding Drive
120
May 29, 2025 9:23 am
E62.00 fault in inovance IS580 drive indicates Braking IGBT short-circuit. This means the braking IGBT has detected a short-circuit condition. Essentially, the braking transistor (IGBT) inside the drive's braking circuit has either failed or detected an abnormal condition that looks like a short circuit.
- Power down the drive immediately to prevent further damage.
- Inspect the braking resistor and wiring for: open & short.
- Measure braking resistor resistance with a multimeter — it should match the specified value, no short or open.
- Check wiring and terminal connections for damage or loose connections.
