Inovance CP700 – Air compressor & IS580 – Injunction Molding Drive
118
May 29, 2025 9:28 am
E63.00 fault in inovance IS580 drive indicates Reverse running time reaches A4-09. This means the drive has detected the motor running in reverse direction longer than a configured time limit.
- Increase the value if your process requires longer reverse operation.
- Verify the commands that make the motor run in reverse are correct and intentional.
- Ensure they correctly detect motor direction.
- Ensure nothing is forcing the motor to run backward unexpectedly.
