Inovance CP700 – Air compressor & IS580 – Injunction Molding Drive
112
May 29, 2025 9:50 am
E67.00 fault in inovance IS580 drive indicates Parameter initialization fault. This means the drive encountered a problem reading or loading its internal parameters during startup or initialization.
- Power cycle the drive: Turn off the drive completely. Wait 1–2 minutes, then power it back on. Sometimes a simple reboot clears temporary memory errors.
- Reset to factory settings.
- If the drive cannot be reset or parameters cannot be recovered, the internal memory may be permanently damaged.
