Inovance Drives
2,249
Jun 10, 2024 12:16 pm
Inovance drive error code 23 signifies a ground fault or a hardware issue within the drive itself.
Here's a breakdown of the error and potential causes:
Error Description:
- Code: 23
- Meaning: Ground fault or hardware issue
Possible Causes:
- Ground Fault: Leakage current might be flowing between the drive's internal components and the ground. This could be due to damaged insulation, moisture ingress, or other electrical faults.
- Hardware Malfunction: A malfunctioning internal component within the Inovance drive could be causing the error.
Important Note: Troubleshooting electrical components, especially those with potential ground faults, can be risky. If you're not comfortable working with electricity, it's strongly recommended to stop here and seek assistance from a qualified technician.
If you do choose to proceed:
- Turn off Power: Before any troubleshooting, ensure the Inovance drive is completely powered off and disconnected from the power source.
- Visually Inspect Drive: Carefully inspect the drive's exterior for any signs of physical damage, burns, or burning smells.
