inovance drive error code 731
Inovance drive error code 731 indicates a problem with the encoder battery. The encoder is a crucial component of a servo motor system, providing feedback on the motor's position and speed. The encoder usually has a small battery that helps retain its settings even when the main power is off.
Here's a breakdown of the error and how to potentially resolve it:
Error Description:
  • Code: 731
  • Meaning: Encoder battery failure
Possible Causes:
  • Low Encoder Battery Voltage: The battery voltage in the encoder might be too low to function properly.
  • Missing or Incorrect Battery: The encoder might not have a battery installed, or the installed battery might be the wrong type.
  • Encoder Malfunction: In rare cases, the error could indicate a problem with the encoder itself.
  1. Check Battery Connection: Ensure the encoder battery is properly connected to the encoder.
  2. Replace Battery: If the battery is connected, it's likely depleted. Locate the correct replacement battery based on the encoder model and replace the old one.
  3. Reset Drive Parameter (H0D-20): Some Inovance drives allow resetting a parameter (H0D-20) to acknowledge the encoder battery replacement and clear the error code.
